Paint questions for built-in bookcase?
I've spent the better part of the evening reading through the posts and learned many interesting tips.
I plan to go to S-W over the weekend (they are having a sale) and buy paint for my latest project. I will be painting our family room in a satin/eggshell finish. Also, recently we had a built-in bookcase added to the room. (Nightmare story for another forum!
Right now the bookcase is unpainted and just has a single coat of primer on it. I think it would be nice to match the door and window trims to give the room a pulled together look.
Here are my questions:
1) Should I paint it in a high-gloss or semi-gloss? It will have books and stuff on it. I have a feeling my toddler will take over the bottom shelf for his toys.
2) Should I paint it with a roller, foam rollar or paintbrush?
3) Do I need to put a clear coat on it when it's finished being painted for more protection?
Thanks in advance!! I look forward to your replies.
Mari
Mari
It's a matter of personal preference at this point
Either is better than flat for cleanablity, which may be an issue on the lower shelves
Personally, I would use a good quality pad for a bookcase, or just brush it
I wouldn't want the slight texture left by my rollers on the bookcase
But really any way would probably do just fine for you
Ask at the SW store, tell them what you are doing
They should suggest a good durable paint for you
I often paint shelving for commercial clients, a very rough environment, and I don't clear coat them
...though some extreme cases I do use a heavy duty floor paint
Originally Posted by marksr
...SWP's proclassic waterborne enamel for your bookcase...
I haven't used that yet, I'm waiting for the next chance to try it though
I was thinking of painting some trim around the house, just to try it
