Painting MDF
Old 12-25-05, 07:06 AM
C
Painting MDF
I thought I heard something about the grain raising up on MDF when it is painted. In any case, what is the best primer/ procedure to use before the top paint coat is applied. We'll be using satin white, and they will become small bookshelves. Thanks in advance and Happy Holidays.
Old 12-25-05, 08:57 AM
I don't think MDF has grain. If you are worried use an oil based primer like coverstain or bin[both from zinsser.com] and lightly sand before you topcoat with what ever you want.
Maybe use some of that waterborne paint from SW. It is tough and you may need it.
If you are using square edged MDF I would ease the edge a little with a sander to help prevent chipping.
Old 12-25-05, 10:11 AM
Received 800 Upvotes on 703 Posts
I've never had any grain issues when painting MDF. I usually prime it with latex undercoater.
If you intend to place heavy books or objects on the shelves I would recomend either using oil base enamel or waterborne enamel. They dry harder than most latex. With some latex setting heavy objects on them for any period of time often leaves them sticking to the surface.
MERRY CHRISTMAS
