How much area do you apply the primer?
I recently removed all cabinets in my kitchen; patched all holes; sanded to the best I could. I believe I do need to prime first, since there are at least 3 kinds of old paint colors in various places; new patch work; some drywall showing, etc.
My question is: how detail do I have to be with primer? Do I need to paint over the whole ceiling, walls, cutting in first, and use tapes to cover fixtures? Or, do I only need to basically cover the darker areas and make sure all is somewhat uniformed in the primer color (white)?
Thanks
Thanks
Joneq must be the only guy that cleans before he paints. You must thoroughly clean all painted areas including the ceiling before doing anything. Especially in the kitchen.
What kind of paint is on the wall now oil, latex, gloss. semigloss.It makes a difference. You cannot just paint semi gloss or gloss paint . If it is oil based paint you cannot prime with latex primer. If you do not know what you have use Bullseye 123 or Coverstain to prime everything after you completely degrease and clean.
The primer can be tinted close to your finish color. It does not have to be white. unless you plan on painting white or close to it. If you are not painting pure white I would tint it.
