best primer?
Old 01-31-06, 12:06 AM
L
best primer?
What would be the best primer to use for filling small cracks and holes.
Old 01-31-06, 05:12 AM
Received 2 Upvotes on 2 Posts
A primer is best to cover the filled cracks and holes before painting
For nail holes and small cracks I use a latex "spackle" hole and small crack filler
It's made by Elmer's
I usually don't need to primer over repairs made with that
For bigger repairs, I use joint compound
I'll spot prime them, usually with whatever I have open
I try and keep a can of Pittsburgh Primer/Sealer in the van
Unless it's a problem area in which case I'll break out a Zinsser product depending on the problem
Old 01-31-06, 07:04 AM
Received 742 Upvotes on 648 Posts
With the exception of elastormaric coatings [for masonary] paint is not used to fill cracks. Sometimes they will look filled while the paint is wet but unless you use spackling or j/c the cracks will reappear.
Old 01-31-06, 02:34 PM
prowallguy's Avatar
Received 1 Upvote on 1 Post
A wise man once told me:
"Paint covers, but it don't fill."
Old 01-31-06, 04:42 PM
B
What they said!
