Smooth Painted Surface
Received 0 Votes
I am painting some large flat surfaces (like a flush door) with gloss latex. I have tried adding Flotrol, using a foam roller, using a foam brush, and using a good grade clean polyester brush. I get orange peel with the foam roller, ridges with the foam brush and brush marks with the brush.
Aside from spray painting, what is the best way to to get a smooth painted surface on these large flat panels?
Received 0 Votes
The brand I have a problem with is Behr (it is a bear to level)! I am going to switch to Glidden which I like much better.
What brand do you recommend for the best leveling properties?
Received 0 Votes
The brand I have a problem with is Behr ... I am going to switch to Glidden which I like much better.
For what you are looking for I'd recommend neither
I would (also) recommend Ben Moore's Waterborne Impervo and Sherwin's Waterborne ProClassic
The difference between those and B or G is astounding
Received 0 Votes
painted flat surfaces
Excellent choice in paint choices.doesn't get much better than that.Techniqu e and patience also plays a big factor.If it's not to late you may want to think about oil paint. ( I KNOW THE SMELL AND CLEAN UP) but the end result. oil paint lays down a lot better which intern levels out quit a bit better than latex. what kind of heat do you have in your home.That can also make or break a paint job. GOOD LUCK.
