flat into eggshell ??
Old 02-07-06, 11:22 AM
G
Question flat into eggshell ??
Would I be able to put a few drops of flat into an eggshell from a different company to get a hint of off white? Both are latex and premium paint.
Old 02-07-06, 12:58 PM
Received 742 Upvotes on 648 Posts
All latex paints are interchangeable but when mixing 2 different bases it will change the properties of the paint. Adding flat to eggshell will result in less sheen and possibly less washability. Whenever custom mixing 2 paints together be sure you have enough to do the job as it isn't likely you could both duplicate the color or sheen.
Old 02-07-06, 02:15 PM
Annette's Avatar
what 2 colors are you mixing to produce "off white"?
Old 02-07-06, 06:08 PM
N
Take it back to where you go it from and ask them to add some colorant to it. Or take it to a local paint store, they'll usually do it for you as well.
Old 02-07-06, 07:22 PM
B
Yes, the best option is to take it back and add pigment.
