Sealing Window Sills
Received 0 Votes
I have a new home with processed wood window sills painted white. I would like to seal them against moisture damage. Could someone suggest what to use? Thank you...! ! !
Is this interior or exterior sill?
Interior sills should be painted with enamel, either latex or oil base.
Exterior should be a good quality latex. Flat is ok but satin or gloss would be better.
Received 0 Votes
You're wise to seal those puppies while they're new. That particle board rubbish swells and distorts with moisture. I sanded the bumps off the sills in a 20 year old condo with an orbital sander. When I applied primer the sills swelled up all over again from the moisture in the latex primer. 'Twas a mess. Perhaps I should have used oil based primer??
