What is the life span of paint/primer?
Old 02-25-06, 02:40 PM
G
I need to primer a wall. I had left over primer in 5 gal buckets from the first time I painted the walls. The buckets had a good seal and the primer still looks good, there's about 2-3 gals of primer in each bucket. This primer is about 5 years old, is it still good to use?
Old 02-25-06, 03:49 PM
Received 742 Upvotes on 648 Posts
If it mixes up well it is probably still good.
Old 02-25-06, 04:21 PM
Received 2 Upvotes on 2 Posts
Should be
You'll know if it's not when you try and mix it
