Bad paint job
Old 02-27-06, 07:36 AM
Received 1,187 Upvotes on 1,145 Posts
Bad paint job
I messed up: was patching some dings in the walls at the office. Had the spackle smoothed and was applying primer when I got distracted by people coming in and the phone ringing. The primer ended up way too thick in one spot, but I thought the paint might cover it. Of course, it didn't. I have sanded the spot down, but now I'm not sure what to do next. The spot is nearly smooth as glass and I'm wondering whether I should prime and paint, or just paint? I did not sand through to the spackle, so I was leaning toward just paint, but I'm getting a little tired of this wall and want this time to be the last time I have to deal with it.
Old 02-27-06, 08:18 AM
Annette's Avatar
all spackled & patched areas need primer or else the paint will dry differently on those areas.
Old 02-27-06, 08:35 AM
Sorry, I apparently wasn't clear: spackled, sanded, primed and painted, but the primer was too thick and the finished paint job was awful. Have now sanded smooth without getting down to the spackle. Do I still need to prime this first for adhesion of the paint because the wall is now nearly smooth as glass?
Old 02-27-06, 08:49 AM
Annette's Avatar
if the paint will be touching only primer and not spackle, you're fine.
Old 02-27-06, 09:02 AM
Thank you, ma'am.
