painting molding
Old 03-28-06, 12:05 PM
R
painting molding
I have some base molding that i want to paint with a roller snce it will be much faster than a brush. Will I get a smooth finish on it? I notice that a roller on walls leaves just a hint of texture (I think) but Im not sure if thats the roller, or the sheetrock.. or my imagination.
Old 03-28-06, 12:34 PM
Received 1,287 Upvotes on 1,225 Posts
You're not imagining, it's called roller stipple. Typically, a 1/4" nap roller is used when a smooth finish is desired.
Old 03-28-06, 01:02 PM
R
so if I use that, it will be as smooth as a paintbrush?
Old 03-28-06, 01:34 PM
Maybe, depends to some extent on your skill. Oil based paint tends to stipple less than latex, so that also might be worth looking into.
Old 03-28-06, 01:50 PM
Received 874 Upvotes on 765 Posts
No roller [even 1/4" mohair] will give a stiple free finish. Since base is low it is unlikely the stiple will be noticed if a good job is done. Check out some of the mini rollers as they are ideal for this.
Old 03-28-06, 03:27 PM
mjd2k's Avatar
I like to paint moldings prior to install but because of profiles, a roller doesn't work too well for me.
I do use a little 3 inch roller to roll the tops of unintstalled bbds because I can do that in one swoop but I brush the fronts and then wipe the backs and bottoms to keep off drips.
A couple 2 foot aluminum saw-horses work real well as drying racks.
Old 03-28-06, 06:16 PM
Received 3 Upvotes on 2 Posts
Yup
If that was possible we'd be all over that lol
