painting over varnish
Old 04-06-06, 06:47 PM
john angone's Avatar
can a door sealed with thinned varnish be painted with either oil or latex paint?
Old 04-06-06, 06:51 PM
Received 102 Votes on 94 Posts
It would be best to prime it with an oil base primer, you can then use either oil or latex for the finish.
Old 04-06-06, 08:18 PM
this old door
the door has some really raised grain and feels what can only be described as "hairy" after sanding it down. is there anything i can put on it then sand to smooth it out, before painting it?
Old 04-07-06, 06:15 AM
Sand the door with 120 grit and then prime with oil base, sand again when dry. The door will then be slick and ready for paint.
Old 04-07-06, 08:00 AM
Normally this wouldn't be filled, it would be sanded
It should work as marksr described
