Chip/Scratch resistant paint?
Old 04-07-06, 09:35 PM
F
I've built a window seat in a bay window. I've used a maple faced ply and edged it with a maple sill so from a wood stand point it will resist dings and dents from normal wear and tear. We're not going to put a cushion on it but I imagine that it will get sat on from time to time (reading a book in the morning sun etc.).
I was thinking about giving it a couple of coats of white floor paint, after my usual over kill of 3-4 coats of primer and sanding for a smooth as a baby's butt look.
Is the floor paint overkill? Will a good quality oil based enamel be good enough? I'm worried the floor paint would look a little ropey.
Old 04-08-06, 10:42 AM
Received 742 Upvotes on 648 Posts
No reason for floor enamel to be ropey if applied correctly.
Both oil and waterborne enamel should dry plenty hard enough for the job.
Old 04-09-06, 06:08 AM
Received 2 Upvotes on 2 Posts
I use floor paint on walls in some commercial bathrooms
Also some other high use/wear non-floor spots
Works great
I like Ben Moore's Floor & Patio water-based off-hand
I'm sure the other major brands have good ones also
Old 04-10-06, 06:42 PM
prowallguy's Avatar
Received 1 Upvote on 1 Post
You want overkill, apply a 2-part epoxy. That is truly bulletproof.
Old 04-12-06, 06:02 AM
F
Thanks for the replies, I'll give it a go.
