How to roller paint a 25' Wall?
Old 04-20-06, 05:34 PM
C
Cool How to roller paint a 25' Wall?
I just finished painting a 15x25 bedroom, the two long walls are almost all drywall except for 2 windows on one and 1 double door on the other. Starting at the top I painted about 1/2 the width and about 30" down, then went back to corner and started over. Is this recommended or is it better to roller all the way across wall then start over? Thanks for your help.
Old 04-20-06, 09:47 PM
Received 1,188 Upvotes on 1,146 Posts
How you want to do it is up to you, but you always want to be working with wet paint. If you paint up to a point and let it dry before you come back to it, you can be left with a visible difference between the two areas.
Old 04-21-06, 03:34 AM
C
Thanks for the info
Old 04-21-06, 08:54 AM
Received 741 Upvotes on 647 Posts
I'm not sure I understand. Usually you would cut in and then roll to each break in the wall [window/door] and continue in that manner.
Old 04-21-06, 04:02 PM
C
Each wall had been cut in, 1st wall has 20' from door to corner, 2nd wall has 20' between windows. No other breaks in either wall.
Old 04-21-06, 04:15 PM
You always want to cut in a section first and then roll top to bottom as you work your way down the wall.
Use a roller pole [screws into end of roller frame] to assist in rolling from floor to ceiling.
