Interior primer under exterior paint?
Old 04-28-06, 07:00 AM
W
Hi guys,
I have a bunch of pine planks to pint. They're not not PT, just clean white pine wood. They will be outside. I plan to prime with Kilz and topcoat with SW Superpaint.
What is the danger of using interior primer and covering with exterior paint? The Kilz exterior is like paste but the interior can be had in rattlecans. That sure would be easier. Can I get away with it?
Thanks!
Tom
Old 04-28-06, 09:29 AM
If you're taking the time to do the project, why not spent $20 and get the proper primer? You can get a gallon of Cover Stain for less than that.
Old 04-28-06, 09:31 AM
W
Its not the money, the amount of spray cans needed would cost more than the gallon of primer. Its just that it would be so much easier with the spray. I'm beyond sick of painting lately.
If it won't do a good job I won't do it, just thought I'd ask.
Old 04-28-06, 09:35 AM
Annette's Avatar
buy a paint sprayer. it'd be a good purchase as you'll surely use it again.
Old 04-28-06, 09:41 AM
The original Kilz works on bare wood
You should be able to "get away with it" lol
I can't remember doing it myself, but I can't see why it won't work
It won't really be cost effective if you have a lot to do though
It's expensive in the rattle cans
*I do have to point out, as I'm sure you know, an exterior primer would be the proper way
Old 04-28-06, 09:47 AM
W
I figure the primer makes the paint stick but the true protection is in the topcoat.
I don't know if I'll do it this way or not. I feel like I've been painting for months, everything I do has to be painted first, ya know? I'm tired and I'm whining about it
Thanks much for the replies! I do know that using the exterior primer would be the proper way
Old 04-28-06, 11:05 AM
Annette's Avatar
wait a minute......you've got flat boards to paint? how is using spray paint easier than a brush or a roller? i've used spray paint before & i don't think it's easy at all. the fumes are horrid, the overspray is annoying, and getting even coverage is very difficult. a small roller would be the way to go.
Old 04-28-06, 11:06 AM
W
Originally Posted by Annette
wait a minute......you've got flat boards to paint? how is using spray paint easier than a brush or a roller? i've used spray paint before & i don't think it's easy at all. the fumes are horrid and getting even coverage is very difficult. a small roller would be the way to go.
<shrug> I find it easier and faster to use the can than the thick primer.
Old 04-28-06, 11:07 AM
Annette's Avatar
it's primer. how thick can it be? are you sure it hasn't gotten old or something?
Old 04-28-06, 11:09 AM
W
Kilz exterior primer is thick. After a while its like spreading paste.
Old 04-28-06, 11:18 AM
Annette's Avatar
hmm.......would it go on easier with a roller than with a brush?
Old 04-28-06, 11:21 AM
W
Yea except for the edges. Its just that I'm tired of painting under the sun sun in 95 degree weather every weekend
Old 04-28-06, 11:38 AM
Annette's Avatar
you could still do the edges with a roller. roll the edge first then smooth out whatever globs onto the front or back. on TV i see them using those little wiener rollers all the time.
Old 04-28-06, 11:40 AM
W
I don't have a wiener roller No big deal, most likely I'll roll and brush on the proper primer. Slick got me feeling bad about being lazy!
Old 04-28-06, 01:07 PM
Wha'd I do?
I had to say the "proper way" thing
I can't have all our DoItYourself.com Community Forums > Interior Home Decorating > Painting > Thread readers think it's perfectly normal to use interior stuff outside
Then they'll all start using Kitchen & Bath paint on their decks
Complete Anarchy!
That's too bad
They're great for priming planks
Old 04-28-06, 03:15 PM
Received 398 Votes on 354 Posts
Paint thinner is sold for when the material won't apply correctly for the given job. That said I would only use rattle can sparingly -THEY DON'T PUT OUT ENOUGH MATERIAL.
If you are going to paint for a living, you really need to invest in a wiener/cigar roller or even one of those 'wiz' rollers. Once you use one a couple of times you will kick yourself for not buying one earlier.
I would also second slicks' comment that while you can occasionally get away with using the wrong material [interior primer-this case] it is always better to use the correct material for the job.
Old 04-28-06, 04:40 PM
W
Ack! Paint for a living? Save me from this terrible fate! I'm just trying to put a broken porch back together!
Thanks for all your help folks. I'd have a terrible time getting things right without you.
I'll be using the correct material for the job I don't even know what a wiener roller is!
Old 04-28-06, 05:14 PM
Hot Dog Rollers
Technically called "Mini Rollers"
Wee lit'l four inch jobbies
Old 04-28-06, 05:32 PM
Ack! Paint for a living? Save me from this terrible fate! !
Sorry, my fault I've been on vacation [maybe my brain still is ] and I confused you with wannabe who is just starting out as a pro painter.
Old 04-28-06, 05:40 PM
B
It could be worse - doing all that painting and not getting paid for it
  #21
Old 04-29-06, 03:01 PM
W
Well, the promised beautiful day didn't show up, it was cloudy and looked like it might rain all day so I didn't paint.
I did the cuts done and got my supplies; a fresh can of Kilz exterior and some wiener rollers Maybe I'll get the painting tomorrow.
Thanks again!
Paid? I wish! This is all my stuff,
  #22
Old 04-29-06, 06:03 PM
.... a fresh can of Kilz exterior and some wiener rollers...
Boy now doesn't that sound like paradise
Nuthin' like a fresh can of Kilz exterior and some wiener rollers
  #23
Old 04-29-06, 06:20 PM
B
A little yellow paint is all he needs for those weiner rollers.
I relish the thought.
  #24
Old 04-29-06, 07:01 PM
W
You guys are having too much fun with this
  #25
Old 04-30-06, 08:24 AM
W
First side and edges primed. Will flip and complete in an hour or so. You guys were right, as usual, those little rollers are great for this.
Won't get the topcoat done today, just not enough hours
  #26
Old 04-30-06, 11:12 AM
mjd2k's Avatar
Don't be such a hotdog.
  #27
Old 04-30-06, 11:59 AM
...those little rollers are great for this.
Hooray for weiner rollers!
  #28
Old 04-30-06, 12:13 PM
W
Absolutely! Last ones are drying now.
