what is back rolling
Old 05-08-06, 02:48 PM
VC-Racing's Avatar
i am in the process of replacing my siding own my house with a fiber cement ( certianteed weather board) and i keep seeing the term "BACK ROLLING" if the siding is being sprayed. does anyone know what this means ?? i will be ready to start painting in the next week or so, i'm trying to get everything ready so when i start i can finish..
Old 05-08-06, 03:16 PM
Received 741 Upvotes on 647 Posts
Backrolling is rolling over the area sprayed to work the paint into all the crevices. Sometimes you will also back roll paint that has been rolled on heavily - to smooth it out.
The manufacture wants to make sure you get a good coat of paint on their product. Brushing and/or rolling will achieve that. Spraying alone can leave some areas not fully covered [protected] with paint.
Old 05-10-06, 04:35 PM
VC-Racing's Avatar
thanks for the reply Mark , so if i sprayed 2 coats would i still need to backroll? i am using a commerical sprayer not some powerpainter that dribbles paint all over.
Old 05-10-06, 04:48 PM
Received 2 Upvotes on 2 Posts
Originally Posted by VC-Racing
... if i sprayed 2 coats would i still need to backroll? i am using a commerical sprayer...
I am not familiar with the substrate, but if it says backroll, then you at least have to backroll the first coat
...lol on the dribbling powerpainter...
Old 05-10-06, 05:32 PM
I agree the first coat [or atleast 1 coat] would need to be backrolled. It doesn't really matter what type of airless you use [unless I'm the one spraying ] you still need to backroll. Spraying applies the paint on top of the substrate while brushing or rolling will work the paint into the surface.
Although it doesn't work for all coatings or substrates when feasable you can spray, backroll and then spray again which gives you good coverage in one application [3 steps]
Old 05-11-06, 02:37 PM
VC-Racing's Avatar
ok, thanks , i guess i can get the wife to assist.
Old 05-11-06, 04:27 PM
One person can spray and backroll although it is a lot harder doing it all yourself but........ would hate to see a fellow diyer in the dog house
Old 05-14-06, 06:21 AM
VC-Racing's Avatar
Arrow
Its way to late for that , i stay there, the dogs have it good though , they have a 20 x 20 kennel and each one has there own Dog Igloo ,i installed a vent fan system so in the summer it won't be so hot and in the winter i've got side covers to keep the wind out . So staying in the doghouse really ain't so bad
