Eaves are killing me
I started painting my house a few weeks ago. After replacing a wall of siding, some scraping, some hosing, some priming, I finally started painting with a brush yesterday afternoon and night.
My hands still hurt.
Ok, stop laughing. I am painting the eaves of my single story SoCal house with a 3" Purdy brush and it's killing this DIYer. So, I did some searching about a sprayer and checked here. The last couple of houses I painted was about 20 years ago.
Considering that I am using exterior Behr latex paint, most of the house is stucco that doesn't seem to need paint, and that I sit on my butt most of the day at work, does it make sense to use an airless sprayer for the eaves and the rest of the siding?
If I was doing it, I'd have a 5 gallon bucket of paint, a roller screen in the bucket, and I'd paint the majority of the soffits with a roller and a long extension handle. It would leave much less to brush. You can do all the rolling from the ground with the paint pole, and you would only need to be on the ladder to get what the roller can't get- edges.
Unless you have spraying experience it isn't a real good idea to buy an airless just for one job - they can also be rented.
If brushing I would probably use a 4" brush. As XSleeper posted using a roller will speed things up quite a bit. Brushing or rolling will also work the paint onto the surface better than spray possibly making for a longer lasting paint job.
Roller on soffits?
Thanks for tips. I am unclear on using a roller on the soffits. The eaves are about 16 inches apart and made with 2 x 6 beams with tongue in groove "ceilings". Would you use a small, say 4" roller on one eave then go up the ladder and get the corners with a brush? Then move to the next eave?
I was picturing a flat soffit as you usually see on 1 story ranch style homes. In your case, you might be able to do some of it from the ground, but then yes, getting on a ladder with a 4" roller might do the rest and be faster than a brush. Then have the brush handy to brush the corners. At least your wrist might last longer that way.
Sometimes called Hot Dog rollers
The covers with the nap though, not the foam ones
The minis have nap on the ends, and get into the corners well
If I can't get into the corners with it for some reason, I'll stick a brush in a holder on the pole, and get them that way
No ladder, just a good extension pole
SO much better
Thank you for the mini roller suggestion! That has saved me hours and much back, neck, wrist, arm and hand pain. Finished the largest stretch of the eaves much faster that way. I sure am glad for the kind people of this forum. Thanks again!
