Whitest Ceiling paint?
Which company makes the whitest ceiling paint? I have access to Home depot/Benjamin moore and Lowes.
It's funny, the "whitest" ceiling paints actually have a little blue in them
Of the Behr, AmTrad, and BM, I cam tell you regardless of the actual whiteness, it'll be much better looking with much less work to go with the BM
Originally Posted by phatmax
I have heard negative things about benjamin moore ceiling paints, is it true? What is BM color called?
I find that difficult to believe
I've never heard a bad thing about them, from pros or DIYers
(maybe some pros have a preference of another brand, but that's common...but none I know will touch Behr or AmTrad)
I suppose anyone could have a bad experience with a project
I'd consider the source
Also BM, like the other national brands, has Mid-Line and Lower-Line products, so a person could use a low-end BM, and think it is not that good (which it isn't bad, but it's no premium product)
Ceiling White is the color/paint you are looking for
I'd recommend ceiling paint, but if you wanted to go with any of the other whites in flat wall paint you could
It won't have quite the adherence and dripless factors a true ceiling paint would, but it's more than do-able no problem
If you wanted to avoid the BM ceiling, I have used the Sherwin Williams ceiling paint and it works great also
Maybe a little more splatter than the BM, but then I'm going faster then most DIYers so maybe you might not notice it
Not a fan of Ralph Lauren paint at all. Ranks up there with Behr and the other over-promoted under-performing products.
For the whitest ceiling paint, use a high-quality flat paint, in a bright white, or super white. Beware of Sherwin's luminescent line, its very hard to make cover, even white over white.
I use 2 coats of Ben Moore Regal Wall Satin in Brillian White for bright white on ceilings.
Also know that most true ceiling whites have a shot of blue or gray in them to help hide defects and whatnot. If your ceiling has any imperfections at all, bed tape seams, dings, patches, etc., they will show up more with a bright white.
I've not been impressed with ralph lauren paint either although what little I have applied has been with troublesome colors.
