How to paint underside of crown molding
The correct way is to paint the entire moulding with the trim paint. This is easiest to do if the crown is painted before the walls are. There are many who 'cheat' and don't paint the bottom edge with the trim color.
I've always done this area with the trim color. While it is easier to paint before putting up, I inevitably have to run a brush along this edge afterwards. Tape the wall or use a wide putty knife.
I am a professional painter and it would be no problem for me to just cut that in. For you, I would suggest to do the best you can and if you get a little paint on the wall try to clean it off or touch it up with the wall paint. If your using a flat paint for the walls then it should touch up nice. I love flat paint because it touches up so nice.,,,Also , You could use some painters tape and dry brush it{like you would if stenciling} and pull up the tape while still wet. Just make sure the brush has very little paint on it. If you have a a lot or even a normal amount of paint on your brush , it will get under the tape and make a mess. because you are using flat paint you can touch up any boo boo's pretty easy.
