Rust-Oleum Tub and Tile any good?????
Old 08-19-06, 09:38 PM
Does anybody have any experience or knowledge of this product and if it is any good? How about ease of use? Thanks
Old 08-20-06, 04:12 AM
Received 120 Votes on 107 Posts
I have not used this product. IMO it is never a good idea to paint ceramic tile. I don't know how ths product compares to the other tub paints but I do know the #1 reason for diy tub painting failures is caused by improper [or lack of] prep.
Old 08-20-06, 05:09 AM
majakdragon's Avatar
Continuing with what Marksr said. Most posters here have not obtained the results they had hoped for using a DIY tub paint. It was either bad from the start or failed in a short amount of time. There is no "ease of use". Lots of prep. If redoing a tub, you need to remove the drain flange assembly or that is the first place it will fail. Good luck.
Old 08-20-06, 05:35 PM
I have not used the product either
But I would like to add that I haven't used any that worked satisfactorily, nor have I heard of someone using any that worked satisfactorily
