Paint or drywall over plywood walls?
Old 08-29-06, 08:32 AM
I have a Gunderson home (if you know what that is) and all the inside walls are plywood. Some have wallpaper over it and some or just varnished. If I paint over it there will be seams visable where the 4 foot section meet. Now aside from drywalling over this, is there some way to even up the seams and just applying paint to make it look like a finished wall?
Old 08-29-06, 09:58 AM
Received 120 Votes on 107 Posts
You can remove the strips and fil them in with joint compound or durabond but it will crack if there is any movement of the plywood - settling or shrinking/swelling due to humidity changes.
Also you can't just paint over varnish. First it needs to be sanded and cleaned, then a solvent based primer must be applied to insure adhesion of the paint.
I would recomend either priming and painting with the strips in place or laminating the plywood with 1/4" sheetrock which could then be finished like any other sheetrock.
