cracked paint work
Old 10-05-06, 08:37 AM
C
Thumbs down cracked paint work
Help!!-I have recently painted over walls that I have subsequently realised had a gloss type paint on them. The walls were originally a very dark shade of purple, so i did a couple of coats of plain white emulsion and then a coat of my chosen colour. Since the paint has dried there is rather a lot of cracking. I have since tried to use sand paper to smooth away the cracks and have re-applied a coat of paint. Its a bit better, but I can still see some cracking - how do I remedy this????
Old 10-05-06, 08:54 AM
T
Received 2 Upvotes on 2 Posts
An episode on HGTV this morning showed the effects of painting with latex over oil-based paint. They sanded and scraped walls and primed with a couple coats of primer-sealer with a texture filler which they rolled smooth on the walls.
Old 10-05-06, 11:22 AM
Received 821 Upvotes on 720 Posts
Welcome to the forums
The oil enamel should have had a solvent based primer applied prior to using latex. I doubt a good primer would help much now.
I would sand the walls well and skim coat joint compound over the cracked paint. You can then prime and paint. A texture paint might hide the cracks with out doing a skim coat.
