spray paint
Old 10-31-06, 05:49 PM
L
spray paint
ok hes a good one anyone know how to take away the shine after painting i need it to match rest of unit i am useing a charcoil gray spray can paint
Old 10-31-06, 05:52 PM
Received 870 Upvotes on 761 Posts
Using a very fine sandpaper or steel wool should lessen the sheen. Can you get the same color in a lower gloss?
Old 10-31-06, 06:01 PM
L
have not seen any at home depot with a lower gloss . fine sandpaper or steel wool might scratch it to much i just need to dull it .
Old 10-31-06, 06:18 PM
Try 1000 grit wet sand paper. You may need to go to an auto parts or auto body supply store to find it.
Sometimes burnishing the finish with a soft rag will work. Usually it will give flat a little sheen but it might take away some sheen.
Old 10-31-06, 06:53 PM
L
should i use rag while paint is still wet and if so how wet
Old 11-01-06, 03:14 AM
Received 3 Upvotes on 2 Posts
No, I wouldn't
