Painting Electrial Box inside
I have an electrical box inside a bedroom, akward spot that I can't put a picture over. I would like to paint it the same color as the wall but it is metal. What should I do?
Thanks.
Thanks.
Clean it (dust it off),
Prime with XIM UMA (waterborne) primer, or SW Preprite Bonding Primer (waterborne), or BIN White Pigmented Shellac (Alcohol base, smells like rubbing alcohol)
Paint w/either Latex or oil to match your walls.
Latex of course will be quicker drying, and smell less offensive.
I would roll, to match texture of wall (assuming its rolled).
Good luck. You may consider cutting power to the box on the off chance that some paint runs into a junction. Doubtful, but better to be safe than sorry.
I usually clean, scuff sand and coat them with oil base enamel tinted to the wall color. I wouldn't recomend using flat wall paint for a top coat as it will often get dirty when there is need to use the breaker box..... and I wouldn't want to wash it clean
