exterior priming
Old 12-02-06, 06:19 PM
F
exterior priming
I just replaced the clapboard on the front of my house and I primed it with kilz latex primer and now it is dry but it is going to snow in a day or so now I can't put the finish coat on till the spring.Willthis be a problem?Thanks for your help!
Old 12-03-06, 05:17 AM
Received 318 Votes on 282 Posts
IMO kilz isn't the best primer for exterior siding - I use an exterior wood primer [preferably oil base but latex will often work]
Primers aren't formulated for long time weather exposure but it is better to let it wear away than to paint over it in bad painting conditions. You will likely have to reprime it in the spring but atleast the wood will have some protection.
You may be able to find a good day or two and be able to paint it sooner.
Old 12-03-06, 05:31 AM
F
Thanks very much for your help.
Old 12-03-06, 06:30 PM
It would be helpful to put a coat of paint on it ASAP
Primer makes a lousy top coat, and doesn't offer enough protection
The Kilz latex probably won't make it through the winter
You might want to keep a can of Sherwin Williams Duration or Pittsburgh Manor Hall latex exterior paint close by if the weather breaks soon
All you need is a non-rainy/snowy few days over 35* for those paints
Both are good low-temp paints
If it doesn't work out weather-wise, at least you'll have the paint for spring
