painting paneling?
painting paneling?
Greetings from N.H.
I want to paint some old wood paneled walls. It is paneling from the 60's with the grooves about every 8" apart. Can I use wall board mud to fill the grooves? Should I sand the gloss finish off the paneling? If I want to use a bold color should I have my primer tinted? Or.....am I just making a big mistake and should I remove the paneling altogether? It is really still rigid and sturdy and if I could keep it.....the job could go much faster.
-Thanks.
Bob
-Thanks.
Bob
You can paint it if you'd like
It's a project, but still DIY-able
Scuff sand the paneling
Prime*
Joint compound the cracks
(multiple coats if needed)
Sand smooth
Prime repair areas (latex primer is fine here)
Paint with a quality latex paint, two coats minimum
*If it's in real good shape and is quality paneling, and not too dark, you can use a quality oil-based primer
If it's in negligible shape/quality, or very dark, a white pigmented shellac may be a better choice for priming (but much stinkier)
Prime*
Sand smooth
I have painted paneling several times before, without filling in the grooves. It is a quick easy fix if you don't want to spend a lot of time & effort. You can just use a brush to make sure all the grooves are covered, and make sure that if the paneling was glossy or somewhat smooth that you either lightly sand it or use a primer. Yes, you can still tell that it is paneling if you are paying attention to that, but it looks way better than the old fake wood stuff.
IMO painted paneling with the grooves looks better than poorly filled grooves. Not filling the grooves also makes the joints look better - filled joints are apt to crack later.
As slickshift said, clean and sand, then use a good solvent based primer [tinted will help the next coat cover]
thanks to all for the great ideas.....I'm going to paint it without filling the grooves. I'll post back with results. oh yea.....colors are going to be butternut squash on the bottom with a black chair rail on top of that with the upper wall to be a bold red.
-Bob
-Bob
That would be a pretty popular solution
Most of my painted panel projects have been done this way
It's an interesting look
I've not seen/done one with the split colors
Please post back how it comes out
Good Luck!
Good Luck!
