Removing Sand Textured Paint
Any suggestions on how to remove sand textured paint from a wall? We are not experienced enough to do a skim coat and it is expensive to get a professional to do it around here. Thanks!
Scrape as much as possible off with putty knives (preferably the larger ones)
Then power sand as much as possible off (preferably a random orbital with rough grit paper...100 or 120)
Possibly re-sand with 180, though that might not be helpful as...
You'll still need to skim coat what's left, as there will be either little bumps or little holes left
There really isn't a good reason to be afraid of applying a skim coat. A whole wall/room might be intimidating but I'm sure you wouldn't have any problem skim coating a small square
Just break the wall up into multiple managable squares. Using a checkboard pattern you can skim an entire wall and go back and "fill in" the blanks when the mud is dry. A light sanding will remove any discrepencies in the skim coat.
