labor costs...
labor costs...
Could someone please give me an idea how much it would cost to have two small rooms (12x12) painted? Ceilings too. Primer first then two coats paint.
Thanks
Thanks
Not that I don't want to answer your Q, but...
Labor rates (the largest expense for this type of project) vary greatly from state to state, region to region, and even town to town
Then there's the project itself
Each one can have very different circumstance, time and effort to complete
There's no simple numbers per sq. ft. that work on all repaints
Condition and prep needed can impact highly
I'm not really trying to dodge the question, I just couldn't even tell you what I would charge to do it w/o seeing it, and if I gave you a ballpark, it could be waaaaaaaay off from what you'd actually pay in your area
The best way to get an idea of the going rate for your area is to get 3 estimates
Primer isn't usually needed on interior repaints so it may not be necessary. As slick said labor rates vary greatly - get 3 estimates.
That would be another reason it's hard to say how much it should be
Nic stains add to the price for sure, as that stuff bleeds through paint like you wouldn't believe
It needs a heavy duty cleaning, and then, depending on what's left, a major sealing coat or a minor sealing coat before any painting is done
It's not that the sealers are that much more expensive than primers, it's the labor involved is more than regular prep and prime
