New Cedar Clapboard Bleeding ?
Old 03-30-07, 10:19 AM
R
Hello:
Will be having new horizontal Cedar clapboards put up in a few weeks.
They will be pre-primed, front and back.
Trying to get a bit of a heads up regarding the painting of them afterwards.
The contractor said that "sometimes" there is a bit of bleeding from the Cedar clapboards, thru the primer, once they are up. He also suggested waiting a few weeks before any painting.
Questions:
a. If so, what should be done about this prior to painting ?
b. Or, will the paint (probably 2 coats of latex) cover up any bleeding "for all time" ?
c. No matter what is done, is it likely to continue to bleed again (thru the new paint) ?
Any thoughts on all of this would be most appreciated.
BTW: is this the correct Forum for Exterior painting questions, like this ?
Thanks,
Bob
Old 03-30-07, 01:27 PM
If "bleeding" is a reference to stains penetrating through existing primer then you'd want to paint it with a top quality exterior oil or shellac based stain blocking primer before top coating with better quality exterior house paint.
Cedar is oily and I wouldn't be surprised if there was penetration and that factory primer might not contain it.
Old 03-30-07, 03:58 PM
Received 800 Upvotes on 703 Posts
It is a good idea to preprime cedar and the primer should be an oil base wood primer. It is still a good idea to prime the cedar after it's installed. This will further help to prevent bleeding at cuts and were it's nailed.
Latex paint will not prevent bleeding. A good primer job will!! Dark colors won't show bleeding as bad as light colors will. Bottom line - there is seldom any problems if primed correctly.
Old 03-30-07, 05:21 PM
Received 2 Upvotes on 2 Posts
Yup, re-prime with oil after install
