dry wall
dry wall
I am wanting to cover some very old and rough paneling it is not your smooth lamenated kind it is very rough almost like wood. Can I cover this with texture or do i need to install drywall and if so can i primer and paint it only or do I have to texture before I primer it?
Welcome to the diy forums!
IMO it is never a good idea to texture wood although there are some members that report doing so with success. I'd recomend using one of these 3 options.
#1 - sand, prime and paint the paneling
#2 - install drywall over paneling, 1/4" drywall would be fine.
#3 - remove paneling, add/change wiring as needed, add insulation if needed and install 1/2" drywall.
New drywall can be textured or slick finished - the choice is yours. All new drywall [textured or not] should be primed prior to painting.
