Painting over oil based paint and laquer!!HELP
I want to repaint my kids table and chairs since they are looking yucky after 4 years of kid wear! They are solid wood with white oil based paint and a laquer finish. I really do not want to sand them bare since the chairs would be a pain to do! Is there a product I can just put on the furniture instead and then just paint over again? I don't mind lightly sanding but really have no time to completely sand all the paint and laquer off. I really don't want to use any hazardous/ messy products to remove the old finish either. Any ideas or should I just buy some new furniture???
I'm not sure I understand the oil enamel and laquer finish. Generally laquer doesn't work over oil base.
It shouldn't be a problem to lightly sand and recoat with oil base enamel.
Hmmm... you should be good with a light sanding and an oil-based primer
You'd definitely be good with a light sanding and a pigmented shellac primer, but you'll need lot's of fresh air and a respirator for that stuff
After priming you can use a quality latex or oil-based paint
I'd recommend an enamel for furniture, waterborne or oil-based
