Painting with Accent base
I went to the paint store today and asked for a paint to use on interior bare wood and was given a white latex semi-gloss accent base. I have never actually used this before and when I went to put it on, it was white in the can but was a light milky colour when applied and dried to a clear. Is this normal for an accent base or have I got bad paint or do I need to stir it up alot more than I did. If this is normal do I just brush it on as I would with a normal white primer. I am sorry if this seems like a dumb question but I am used to staining and varnishing wood or using a primer sealer that goes on white and is applied like normal.
Please help
Thanks
Please help
Thanks
You got the wrong base it seems. If its going on milky and drying clear it sounds like you got the Ultra-Deep base. This is a tint base for deep rich colors and contains none of the Titanium Di-oxide used in other bases.
Take it back and tell them you need white base.
