Paint thinner disposal
After a big job and lots of clean-up with paint thinner and such, what does one do with all that spent thinner? You can only re-use it so many times, then you have to chuck it. But where? I want to dispose of it correctly. I don't want to put it in with my normal trash. And where I used to do large commercial painting they had a place like "Clean Harbors" or "Safety Clean" or something pick it up. But what does a small contractor do?
Is there some place I can take it? How can I find out who? What does it cost for disposal(about)?
I hope this is the right forum for this question.
Thanx
Jim
Thanx
Jim
Received 0 Votes
"But what does a small contractor do?"
Fill up a 55gal. drum and have one of those places take it away
(over $500 last time I checked)
Or take it to Haz-Mat day at the transfer station
Received 0 Votes
Most county "clean up days" prohibit commercial waste from businesses. I guess you could fib a bit, and just say it is your own waste. But if you have more than about 5 gallon, good luck.
Best bet is to contact Safty Clean, or some other similar outfit. Drums are the preferred size for destruction, but some places have "mini" drums of 25-35 gallons.
Make sure you keep good records, as this is a business expense that can be deducted, as well as covering your *ss in the event of an inspection by EPA or other governement agencies. (It happens. I had a contractor who ticked of a neighbor near him. Neighbor called EPA and reported he was dumping thinner down drain. Contractor was unable to produce waste destruction records, and faced some SERIOUS legal, and monetary problems.)
