Spray Paint for Base Molding?
I am wondering if they have spray paint for baseboards?
After I lay down the laminate this weekend, I'll be putting down molding. I was thinking about taping it off and using a semi-gloss spray paint. It will probably go on smoother and be a little easier than brushing.
Do they have a special spray paint for base boards that will resist wear? Or would it be better to just brush it on?
Advice? Opinions?
Advice? Opinions?
Stick with the brush!!!
First off the paint in a rattle can is very thin and not alot of it. It would take multiple coats just to cover the baseboard. Then there is all the overspray to contend with - and it can travel a long way
Using a brush will be quicker and you can apply a heavier film of paint = last longer.
Received 0 Votes
Definitely cut the pieces to dry-fit first, then paint prior to installing - then touch up - it saves alot of angst when having clean up paint drips, etc....
On already installed moulding - I always use my wallpaper flat edge smoother next to the base moulding, between the floor and the moulding, to catch any drips and paint spots - you can even use a piece of heavier paper... just make sure it sits lower than the bottom edge of the moulding... Good luck!
