pencil marks
Old 06-05-07, 12:51 PM
A
pencil marks
I am painting my basement, after applying the primer on the drywall, I unfortunately marked the few imperfect areas that needed to be repaired with a pencil. Now after fixing those areas, I started applying my paint and the pencil marks show up.What is the best way to deal with this problem?
Old 06-05-07, 01:15 PM
T
Received 1 Upvote on 1 Post
Guess you could sand them off or you could prime over them.
Old 06-05-07, 01:54 PM
Received 740 Upvotes on 646 Posts
As long as it's a pencil mark [not ink] another coat of paint should cover it. Usually when I run into this I'll either spot prime the marks or hit them with some wall paint prior to starting the finish coat.
You did prime the repairs, right?
Old 06-05-07, 02:00 PM
A
Actually i did not prime the repairs, should I?
Old 06-05-07, 02:09 PM
Ya, you should have but if you have already painted the walls, just touching up the affected areas should be ok.
