painting kitchen
painting kitchen
I was told that I could prime my kitchen w/ oil based primer before I put latex paint over it, is this correct?
There are many instances when it is appropriate to use oil base primer under latex.
Is there a reason you need to use an oil base primer on your kitchen?
paint
I am re-doing our kitchen and we had to put up some new drywall and left some old drywall (w/paint on it) as is. I had a contractor/friend tell me I should use oil base primer over the drywall. I read some conflicting info and was wondering if I should just use a latex primer.
I am redoing the kitchen and I have some new drywall and old drywall (w/paint) and a friend told me I should paint it w/oil base primer. I read somethings that said I should just use latex primer and I want to make sure I use the proper primer.
You rarely need to use an oil base primer on new drywall. Interior oil base primer is mainly for sealing stains and creating a bond on surfaces that are hard to create a bond with new paint.
You should be fine using a latex primer.
Great, thank you!
