Cleaning Flat Paint-HELP
Old 07-09-07, 09:21 AM
Smile Cleaning Flat Paint-HELP
How do I cleaan scuffs and light dirt from my newer flat paint? Approximately 8 months old.
Old 07-09-07, 10:44 AM
Hi
Welcome to the forums
It depends on what the dirt is
But I'd try a Mr. Clean Magic Eraser first
It works with just water, so it's your best place to start
If that doesn't cut it, I like Simple Green
If that doesn't cut it, Soft Scrub With Bleach
Obviously we are getting harsher as we go along, so the chances of affecting the paint are greater
Some types/brands/lines of flats are easier to clean than others, so it's best to start mild, then work your way up
Some don't clean well at all, so you'll figure out if yours is one as you go along
Old 07-09-07, 07:47 PM
Received 131 Votes on 117 Posts
The washability is directly related to the quality of the flat paint! Quality flats can be very washable while the el cheapo brand may not wash at all
Follow slick's cleaning instructions, if that doesn't work you may be able to touch it up with some leftover paint - if you have some.
