Painting Moulding
Painting Moulding
I want to paint brand new baseboard moulding that is bare wood. Can I just primer it and paint it, or do I need to scuff it or anything? I don't want the paint to chip or peel...
Joe
Joe
It is always best to sand prior to priming b ut not imperitive - I usually don't - not enough time You do need to sand the primer lightly when dry. If applying 2 coats of enamel - sand lightly between coats.
I second the use of quality primer and paints. It will make the job easier and look better. The big box stores will sell cheaper coatings but for quality it is best to go to a real paint store.
If you get your paint from a proper paint store, like a Sherwin Williams or Benjamin Moore, I would use whatever primer they recommend to go with your paint and your situation.
SW makes ProClassic, and BM makes Waterbourne Impervo, both of which are excellent tough trim enamels. SW will probably have you get SW PrepRite Classic Primer... I don't know what BM would recommend.
Stay away from the big box stores. While they my have some good products sprinkled in among their selection, if you ask Home Depot what to get, you will be coming home with Kilz2, or even worse, Behr.
SirWired
SirWired
Whichever paint store [not dept] you go to, they will be able to tell you which is the preffered primer for the finish paint you are buying. For new interior woodwork I prefer to use a latex enamel undercoater - unless the type of wood used is subject to bleed, then I'd use an oil base undercoater.
