paint types, air flow, and dust
Old 11-07-07, 06:14 AM
H
Paint section employee a Home Depot mentioned something I've never heard before. He said I needed to use a satin type paint for ceilings, an eggshell type for walls, and (forgot) for baseboards.
Not using these types could (or would) create a dust collection situation due to air flow resistance/restriction.
I found this to be very interesting as my house seems to be a dust trap despite replacing the ac, ac ducts, and carpet in the same month.
Any ideas?
thanks
Old 11-07-07, 06:28 AM
Received 293 Votes on 260 Posts
Depending on the manufacture, eggshell and satin enamels are similiar in sheen [low] I'm sure he recomended semi-gloss for the woodwork.
Dust might be slightly less attracted to an enamel versus a flat sheen. I doubt it would make a difference on the ceiling. Any sheen of enamel is more washable than flat paint. You always want to use an enamel on woodwork although which sheen satin,semi or gloss] to use is basically personal preference.
Generally you will find more knowledgable advice from a paint store employee than you will from a big box paint dept.
All the work you've done recently on your home may be the cause for the excessive dust, if so it should settle down shortly.
Old 11-07-07, 06:59 PM
Not using these types could (or would) create a dust collection situation due to air flow resistance/restriction....
Any ideas?
My idea is the paint selection employee you spoke with is an idiot
Please don't ever ask this person for paint advice ever again
Old 11-08-07, 02:12 PM
Received 94 Votes on 83 Posts
Flat on ceilings is the norm around here. I agree that this particular person should be avoided in the future. Of course, if you follow Mark's advice and go to a paint store, that won't be an issue.
