Large Steel Fireplace, How to finish?
Old 11-20-07, 11:29 AM
Y
I have a Large steel FirePlace which has rusted over the years.
Just want to make it shine and leave the rust which will darken
and look less like rust if it is finished, I think.
http://community.webshots.com/album/...host=communityhttp://community.webshots.com/album/...host=community
This spring, I polished with steel wool & furniture polish spray.
It looked good that day but the following morning did not look like anything was done.
Anyone know what would be a good finish to use?
Thanks in advance!
Old 11-20-07, 02:25 PM
Received 295 Votes on 261 Posts
I don't often get a call to paint anything like that but when I do I almost always use high heat flat black. I don't know if there is a high heat clear finish. You might try asking at a paint store [not paint dept]
Old 11-20-07, 02:38 PM
Y
Has inner flu
The exterior does not get that hot!
You can put your hand on it when there's a fire going.
Old 11-20-07, 02:41 PM
IF heat isn't a factor you can use varnish/poly or linseed oil.
Old 11-27-07, 05:31 AM
Y
Thanks, I'll try linseed oil today!
Old 11-27-07, 05:39 AM
I just realized you had applied furniture polish to the metal - THIS MUST BE REMOVED before applying a new finish.
