Priming new drywall - NEED guidance!!!
Old 11-25-07, 09:47 AM
C
Priming new drywall with Sherwin Williams pre prite 200 (No texture on walls). After I get done with one coat I can still see the mudded areas in comparison to the drywall paper but only when looking down the side of the wall.
My question is - Is this normal? Should I be doing two coats of primer before paint? Or will the 2 coats of paint hide this difference further.
NEED HELP QUICK!!!
THANKS!
Old 11-25-07, 09:54 AM
Received 786 Upvotes on 689 Posts
1 coat of primer is fine! It isn't the primers job to cover - only to seal and provide a good base for the top coat.
Old 11-25-07, 09:59 AM
C
Thanks....I was just reading somebody saying the same thing. I thought it was the other way around since the primer is supposed to be a good "hide" type of primer. I was getting worried that somethig wasn't right!
I feel much better now!
Old 11-26-07, 05:49 AM
Received 1,231 Upvotes on 1,179 Posts
Paint is what does the hiding, primer makes the paint stick better and more evenly and seals the surface to keep what's underneath from bleeding through.
