Flat paint/Semi-gloss paint
Received 0 Votes
I'm painting raw pine shelves for my bathroom and would like to use left over paint. The paint is a flat base. Is there something I can add to the paint to give it a sheen? Or would a clear coat be the best way to go, and if so, suggestions on what kind of clear coat I should use.
Welcome to the forums!
There really isn't anything you can add to paint to give it more sheen. Applying a poly or varnish over flat will give it the sheen of the poly you use but it isn't really a good practice. It may also change the color of the paint some.
It would be best to use a wood primer or enamel undercoater and then top coat with a quality enamel. Save your leftover flat paint for another project
Received 0 Votes
For shelves, don't use paint, use a quality waterbourne enamel. You will get a much tougher finish, and it will be more resistant to sticking to whatever you put on the shelf.
Try SW ProClassic or BM Impervo.
SirWired
SirWired
Waterborne coatings aren't paint
I can also highly recomend the use of a waterborne enamel over primer for the shelves, oil base enamel would be my 2nd choice with latex enamel the last.
Received 0 Votes
Of course, technically, ordinary wall paints are "Water-bourne enamels", but they aren't called that yet...
SirWired
At the very least I would prime and use a semi gloss paint or waterborn acrylic.
I assume the only thing on these shelves would be linen and/or towels? But shelves in a kitchen pantry I would line with "shelve liner". Or better yet cut Formica lined shelving to fit. Then no painting to do.
