Cabinet paint won't dry
Old 01-30-08, 08:41 PM
L
I recently purchased a house and decided to paint the cabinets. They were laminate/particle board (I think). I cleaned them with ammonia and applied paint thinner (I read somewhere that this was what one is supposed to do... although I haven't seen any mention of that on this forum), primed them with BIN primer, then painted them with semi-gloss paint (2 coats). It has been about a month and the paint never completely dried... I'm wondering what I need to do to fix this problem. Do I clean them, sand them, and then paint them again? Thank you for any input.
Old 01-31-08, 04:30 AM
Received 398 Votes on 354 Posts
Welcome to the forums!
It may be the paint that you used. Was it latex enamel? what brand?
Some of the cheaper latex enamels never cure to a hard finish
Old 01-31-08, 05:49 AM
L
I'm not sure about all of the terminology, but I know it was water-based semi-gloss. It was Behr brand.
Old 01-31-08, 06:46 AM
Unfortunately, the Behr can take a month to fully dry
But what you may be running into, the "stickyness", is plasticizer transfer, and/or "blocking" (both big problems with the Behr products), which could continue indefinitely
You could wait another month and see if it settles down a bit
But I'd recommend re-coating with a quality waterborne enamel, like Ben Moore's Impervo or Sherwin Williams Pro Classic
Be sure to get the waterborne, as both also come in oil-based versions
Old 01-31-08, 09:45 AM
I agree with slick, lightly sand and recoat with a better grade of paint! You need to go to a real paint store to find quality coatings - big box paint depts are more concerned with low price than quality
Old 01-31-08, 02:12 PM
L
Thank you! I will try sanding and then will paint again with better paint.
