Benjamin Moore Aura on Trim?
This is my first ever painting project. I started with my living room. Painted the Ceiling w/ Benjamin Moore Regal and walls w/ BM Aura. Now it is time for the trim.
My trim is stained I guess. As I understand, in order to paint it I need to first prime it. Now if painted it with Aura, and as BM claims it is self-priming, do I still have to prime trim?
I want to do a quality job. So if priming is required in either(regal vs aura) case, then I will go with Regal(cheaper). If no priming required w/ Aura then I will go with it to save time.
Thanks a lot.
Thanks a lot.
Welcome to the forums!
Yes you need to prime. It can be difficult for paint to adhere to varnish/poly. You need to use a solvent based primer after scuff sanding the woodwork. I'm not overly familiar with BM products but I'm sure they can suggest the correct primer - it may be their brand or maybe a zinnser primer, oil base kilz will also work although it is the bare minimum.
Self priming basically usually means you can skip the primer on small areas although I understand that aura is totally different and is recomended for use over bare drywall
