Is there a primer?
Old 06-22-08, 12:38 PM
L
Is there a primer?
All the trim around my windows and doorways have a light stain and Polly over it. Is it necessary to sand before painting,or is there a primer that I can use?
Thank you.
Last edited by Shadeladie; 06-22-08 at 12:53 PM. Reason: Removed email address which is not allowed for your protection
Old 06-22-08, 12:47 PM
It would be wise to scuff sand the surface to help with bonding.Also a good quality primer is wise against poly especially if you're putting latex over it.
Not a good idea to post your email address though.
Old 06-23-08, 03:54 AM
Received 785 Upvotes on 688 Posts
It is also better to use a solvent based primer - they will adhere to the poly better than most latex primers and can be topcoated with latex, oil base or waterborne.
I typically scuff sand, wipe the woodwork down with a deglosser and prime with either pigmented shellac or an oil base primer and then apply 2 coats of enamel, sanding lightly between coats.
After the primer has dried and been sanded, caulking all the gaps/joints will result in a professional looking job.
