Painting a fiberglass entry door
Old 06-25-08, 08:00 AM
Thumbs down Painting a fiberglass entry door
Hello,
To paint (not stain) a fiberglass entry door, do I need to use a primer first?
Many thanks,
Majac777
Old 06-25-08, 08:05 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Majac,
It depends on the door. Many are pre-primed. Is this a smooth finish or woodgrain? What does the manufacturer recommend?
If in doubt, prime it out. It can't hurt and would be good insurance. Don't forget under the hinge leafs.
Mark was on earlier...wait and see what he says.
Old 06-25-08, 08:18 AM
Received 786 Upvotes on 689 Posts
I'm not sure if I've ever painted a fiberglass door but it shouldn't need any special primer. It would be a good idea to clean the door first [rinse well] to make sure there are no contamiments to hinder a good bond.
Go to your local paint store [not dept], they are usually qualified for good advice and their coatings will be superior to what you can get at a big box.
