Orbitol or palm sander for fence paint?
Old 09-19-08, 09:21 AM
I want to refurbish an old picket fence. I plan to sand down to the bare wood, prime & paint.
What is better, orbitol or palm sander?
Old 09-22-08, 03:51 AM
Received 754 Upvotes on 659 Posts
Either one will work, neither one will be fun
It would be a lot simplier to scrape, sand the edges of the pait smooth, prime and then paint.
Old 09-30-08, 02:16 PM
Yes, I meant scrape and sand, not to bare wood. Decided to keep the posts and support structure and replace the pickets with new.
Could I get a good coat on the pickets with spray paint from a can?
Old 09-30-08, 03:34 PM
Received 1,197 Upvotes on 1,152 Posts
Sure, but your hand will hurt long before you're done.
Old 09-30-08, 03:47 PM
Paint in an aersol can is very thin so you wind up not applying enough material to get a quality job. You might want to use a small roller to pre prime/paint the pickets before installation.
Old 09-30-08, 03:53 PM
Okay. I will go with a small roller. What would you recommend for attaching the pickets, deck screws or galvanized nails? I have seen arguments for both methods.
Old 09-30-08, 04:08 PM
Screws always hold better than nails although a nail head doesn't show as bad. Sorry - you'll have to choose
