brush or roll oil base paint
what would cover exterior plywood best rolling or brushing on oil base paint i put on a primer and covered with exterior oil paint but the brush marks show not a smoth finish ? I used a good poly and oil brush . If using a roller what type of roller ? I seem to run into sales people of no knowledge . Main question is rooler best or brush
What type of plywood? what is the finished prduct?
1/4" mohair roller cover will give the best results when rolling oil enamel although most any quality roller cover followed by 'tipping out' the paint with a brush will give good results.
My first thought on ths thread was it may just need another coat of paint. Sanding between coats of paint always results in a smoother finish.
