Do I need a protective coat over glazed cabinets?
Old 01-08-09, 10:02 AM
V
We simply cannot afford replacement, SO, I have glazed my thermofoil cabinets. I realize this is not a long term solution, but it will buy me time until I can replace 53 cabinet doors and drawers.
1) I used "No sand" to degloss my doors, then,
2) I used 1qt each of Benjamin Moore's alkyd glaze and satin impervo paint. Honestly, they look good. (If I would to do this again, I feel like SW has a LITTLE bit better adhesion. I tried both, but BM was smoother and easier to apply.)
Since I did not prime, paint, and then glaze , would anybody recommend a protective coating over the glaze? Polyurethane?
Old 01-08-09, 01:06 PM
Received 786 Upvotes on 689 Posts
I don't often do any faux finishes but it would seem reasonable that a coat of clear would protect your finish from wear. Oil base poly will wear the best but will amber the color you have. Waterbased dries clear and doesn't yellow.
Old 01-09-09, 06:03 AM
V
Oil Based poly
If I put an oil based poly over my current glazing, how should I apply it? with a brush, sprayer? I do not want to streak my glazing. The ambering is less important than the duration of the paint.
Old 01-09-09, 02:18 PM
Spraying almost always gives the nicest finish but a good job can be had with a brush without the worry of overspray. As long as the glaze is dry/cured the poly shouldn't hurt it.
Old 01-16-09, 12:11 AM
CAUTION: I wouldn't put a waterborne over that Impervo oil. You may want to check with BM on this cause I'm not so positive a poly will work either.
