Primer/Base Coat
Primer/Base Coat
If I want to paint a wall with a dark color - what type of primer should I use?
Does it change if my color is blue versus red? My colors don't seem to be true once I put them on the wall. Any help??
If you buy your paint from a real paint store [not big box paint dept] you will get a better covering coating and the recomended primer [if needed] for optimum coverage.
Gray primer usually works best for reds, it might be ok for blue, depending on the shade.
Can't vouch for any other brands, but Benjamin Moore specifies a primer for many of their dark colors - it is NOT stock and has to be mixed. The flag on their colors that need a special primer warn the color will NOT be true unless that primer is used.
