painting over polyurethane
Old 01-29-00, 01:46 PM
Guest
Smile
Thanks Raine for the the instructions! I'll try that! Christina C.
Old 01-30-00, 09:52 AM
Guest
Post
Sand it, prime it and paint it. It's okay. Oil base primer is best, however, there are plenty of new WB products designed to be applied directly over oil base finishes. Sanding creates a "tooth" for mechanical adhesion. Coronado makes a WB product called "RUSTCAT". It can be applied to a shinny oil base finish without sanding as long as it is clean. This product will bind chemically, but I still recommend sanding.
Larry Plummer
5824 Corydon Ridge Rd
Georgetown, IN 47122
1-812-949-3013
larryplummer@juno.com
